Hello guys, I would like to know if it’s possible to change the words/labels from pie chart. For example, on this pie chart
How can I change the word “value” to quantity?
My data source it’s MySQL, but I think you didn’t get what I want. The legend has the right names, and I want to show there the values and the percentage, but by default the values have the value word behind, and I want to know if it is possible to change the value word to quantity or something.
Show us your query
My query is
SELECT quantity, p.region_name
FROM mydb.my_table g
LEFT JOIN pt_regions p ON g.region_id = p.region_id
WHERE gas_type = 'CO₂' AND YEAR = (SELECT MAX(YEAR) FROM mydb.my_table)
ORDER BY quantity desc
LIMIT 4;
SELECT quantity as value, p.region_name as metric
Alias to proper column names
Hallo, did you already found a solution to the problem? Because im facing the same problematic.
No, did you?
