v8.3.3 (30bb7a93ca) -
Display legend in the pie chart -
Showing legend as the right-aligned table.
select
now() as 'time_sec',
p.name as 'Plan',
count(*) as 'Count'
from plans_userplan up
inner join plans_plan p on up.plan_id = p.id
group by p.name
What happened?
Legend labels are prepended with Count -
Set a particular column as a legend instead of appending two columns
Remove Count from the legend label. -
