Issues with new Pie Chart
I have started converting old panels to ones introduced in v7+ (I am on 8.1.1) and having a few issues with Pie Chart.
In the old Pie Chart I was able to configure this:
ie, if certain objects (database tables data in my case) were below the above set threshold, they would not ‘eat a chunk of the pie’ on the screen and would be in one bucket. How can I set this in this new panel, so I would not be seeing this below (which makes no sense, plus hogging up CPU and makes the browser slow).
Another thing - old plugin shown label/text “Percentage” w/ Legend if chosen, the new one just display a question mark.
Thanks.
I also have a problem with the new Pie Chart. In the old version, it was possible to change a header in legend. But in the latest version, there is “Value” and “Percent” by default and I can’t find out how to change it.
Snímek obrazovky 2021-08-15 v 16.40.46
Thanks.
As far as I know, you can only add (or remove) Value, Percent and Name to the legend. When you say “change a header in the legend”, what did you want to put there?
I am also having problems with the new pie chart.
In the old pie chart I was able to sort the ranges based on the label, as you see here:
However in the new pie chart the sorting of the ranges is automatically based on the values:
What I would like to have is to be able to sort the ranges by label as in the old version
