Hello All,
I have started using graffana recently and trying to create a dashboard. When I use the below query
sum by (status)(increase(custom_app_products_total{container="app",}[12h]))
I am getting the below result:
I want to show it in a table with status label’s value as column header.
I believe “Label To Field” can be used here but I am not very sure how to use it achieve the expected result. I have already gone through documentation but still not able to understand it’s behavior.
When I am using column mode with value field name as “status” I am getting below result but only for one status at a time:
How can I get all status with respective values ? Please suggest.
Thanks
