I am creating a table panel with a “Series to Row” transformation.
In the Transformation Documentation on “Series to Row”, it reads:
“The result from this transformation will contain three columns: Time, Metric, and Value. The Metric column is added so you easily can see from which query the metric originates from. Customize this value by defining Label on the source query.”
I don’t know what is meant by "Customize this value by defining Label on the source query
My datasource is Graphite.
Below is a picture of the output table and the query.
My interpretation of the sentence I am confused on is: if I define a label on the source query, I can change the column name from ‘Metric’ to the value of the label. If this interpretation is correct, I am not sure how to define a label on the query.
Any guidance would be appreciated.
Thank you
