Column values to labels
    8.1.5
    have a column count of the status field as it’s own column
    eg
    postgres table data example as below
    client=clientA, status=complete, created_at=1234567890
    client=clientB, status=incomplete, created_at=1234567890
    client=clientA, status=incomplete, created_at=1234567890
displayed in table as
client complete incomplete
clientA 1 1
clientB 0 1
    closest I got was
select client, status, count(status) as total from (
    select created_at, client, status
    from tbl_clients
    where $__timeFilter("created_at")
    order by "created_at"
) e group by e.client, e.status
  • What happened?
    I have a multiple rows for the same client with the status per row
    need to rotate the status value (complete,incomplete) to be a label with a count so one line for the client with the status values as a column.
from tbl_clients
where $__timeFilter(“created_at”)
order by “created_at”
I figured it out using a filter on the column.
