8.5.4 on PC
- What are you trying to achieve?
We have raw data logs from PostFix MTAs that are coming into Grafana via Elastic.
I want to turn a column with 4 values into a header row of a table then report on sum of the values
- How are you trying to achieve it?
Not even sure how to go about this
What happened?
I have been reading up on transformations and have tried a few options but can not seem to get the column values of Status to be the header row of the table.
