Hello! In the logs of my network filter, I see that Grafana initiates outgoing connections on IP 34.120.177.193 and 185.199.109.133 (destination port 443 in both cases). 34.120.177.193 is grafana.com, I haven’t found out about the second address yet. Can anyone tell me where Grafana is connected and for what?
See config options:
[analytics]
# Server reporting, sends usage counters to stats.grafana.org every 24 hours.
# No ip addresses are being tracked, only simple counters to track
# running instances, dashboard and error counts. It is very helpful to us.
# Change this option to false to disable reporting.
reporting_enabled = true
# Set to false to disable all checks to https://grafana.com
# for new versions of grafana. The check is used
# in some UI views to notify that a grafana update exists.
# This option does not cause any auto updates, nor send any information
# only a GET request to https://raw.githubusercontent.com/grafana/grafana/main/latest.json to get the latest version.
check_for_updates = true
# for new versions of plugins. The check is used
# in some UI views to notify that a plugin update exists.
# only a GET request to https://grafana.com to get the latest versions.
check_for_plugin_updates = true
