Set grafan to listen only on localhost
How to set Grafana to listen only on community.grafana.com?
Did you bind it to a specific ip address in the Grafana Config or are you using defaults ?
Btw the best way is to use a firewall to restrict access to the used port
Good Luck
I am using default configuration
Please provide result of :
netstat -na | grep 3000
