Unable to use Variable with the Zabbix plugin
Hello!
I’m currently using Grafana 10.3.1 and i cannot use the variable syntax ${var_name}, it simply won’t work! As if i was making a typo. Do i have to enable something in the dashboard or in Grafana? Or am i supposed to use /$variable/ or something else?
Hi @chriscimol,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
I found this documentation link where it explains as how to use variables:
Let us know if this helps.
Hey @chriscimol
you need to use regex “/$variable/” when you are passing a variable and a part of text with the name of the item in zabbix.
if your item in zabbix is:
criticidade alta em hostame
Try creating the item like this:
/criticidade alta em ${host}/
you can see some examples here:
Template Variables Advanced - Training - Dashboards - Grafana (grafana-zabbix.org)
Thank you very much @bernardolankheet, that was it!
