Variable with a regular expression
  • Oracle Linux Server 8.8
  • Grafana 10.1.1
I want to query multiple service statuses from a Zabbix data source.
To make it a bit easier, I’ve set up a constant variable with the following regex value:
all_services = /^Service1$|^Service2$|^Service3$|^ServiceN$/
services_var
Actual service names are very different and have no clear pattern.
I would like to use this variable in some queries.
query_with_var
When I use the variable like this, the query returns no data.
When I use the regex directly, it returns all service states.
How can I use variables with regex, or maybe use a string array?
Not sure if this is still relevant, but I was able to solve a similar issue on my end by specifying additional format options.
Variable syntax | Grafana documentation
For your example use the following when referencing your variable:
${all_services:raw}
That is what I needed!
It is now working. Thank you.
