Unable to set MQTT broker URI when provisioning MQTT datasource in Docker container
Grafana version v11.0.0, which is run from a custom-build docker container.
I’m trying to provision a preconfigured grafana-mqtt-datasource using the MQTT datasource plugin.
I’ve created the following file /etc/grafana/provisioning/datasources/mqtt-datasource.yaml which is installed inside the Docker container:
apiVersion: 1
datasources:
  - name: 'NES_datatown'
    type: 'grafana-mqtt-datasource'
    uri: 'ws://mosquitto:9001'
    isDefault: true
    editable: true
  • What happened?
The datasource is provisioned, however, the URI field is empty, as in the screenshot below (tcp://localhost:1883 is the default value for an empty field).
Bildschirmfoto 2024-06-14 um 14.25.30
Note that fields like the name, isDefault, and isEditable are correctly picked up.
Curiously, when I use the field name url, the URL is shown in the datasource overview page.
Bildschirmfoto 2024-06-14 um 14.28.44
However, it is not picked up in the configuration.
I tried different capitalizations of uri and url but none work.
The URI field should be prepopulated with the specified value.
See above.
No
i would use this reverse approach. create it manually then see what exactlt are the settings generated by grafana itself
Thank you, this worked! For the record, the correct JSON configuration is this:
datasources:
    isDefault: true
    editable: true
    version: 1
    "jsonData": {
      "uri": "ws://mosquitto:9001"
