I’m running Grafana 9.3.6 installed via apt-get on Ubuntu 20.04.5
I have a HiveMQ cloud broker I’m trying to connect to.
Previously I succeeded to connect via mosquitto command line tool and mosquittopp C++ interface. These required me to provide a certificate or certificate path.
- I used the
.pemfile provided by HiveMQ with the command line tool. - I provided the
/etc/ssl/certs/path for the C++ interface (the 1st option did not work out)
Now I’m trying to connect via the Grafana MQTT plugin. I installed it using
grafana-cli plugins install grafana-mqtt-datasource.
When trying to add it in the web gui, I get the following error:
error connecting to MQTT broker: network Error : EOF
I can see some messages going back and forth in Wireshark so I assume the problem is with the certificates.
I tried editing the grafana.ini file without success. It’s not completely clear which file/path should I add where and what other options I need to set. I have been meddling with the following settings but no results so far:
- under
[server];cert_file =
- under
[database];ssl_mode = disable;ca_cert_path =;client_cert_path =
