i am using auto refresh for my dashboard which display several metric value in singlestat panel and sometimes during auto refresh, some panel are showing N/A with error “unable to load datasource metadata”
I am installing grafana and influxDB in docker and using NGINX reverse proxy.
logs and screenshot as below.
any idea what could be the problem.
t=2018-07-05T05:52:32+0000 lvl=eror msg="Failed to get user with id" logger=context userId=6 error="User not found"
t=2018-07-05T05:52:32+0000 lvl=eror msg="Unable to load datasource meta data" logger=context userId=6 orgId=1 uname=fopscore error="Data source not found"
t=2018-07-05T05:52:32+0000 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/3/query status=401 remote_addr=172.19.0.1 time_ms=16 size=26 referer="https://10.64.146.96/grafana/d/yAFWGA7mk/home-ps-core?refresh=5m&orgId=1"
t=2018-07-05T05:52:32+0000 lvl=eror msg="Request Completed" logger=context userId=6 orgId=1 uname=fopscore method=GET path=/api/datasources/proxy/3/query status=500 remote_addr=172.19.0.1 time_ms=18 size=49 referer="https://10.64.146.96/grafana/d/yAFWGA7mk/home-ps-core?refresh=5m&orgId=1"
t=2018-07-05T05:52:32+0000 lvl=info msg="Database table locked, sleeping then retrying" logger=sqlstore retry=0
t=2018-07-05T05:52:32+0000 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/16/query status=401 remote_addr=172.19.0.1 time_ms=23 size=26 referer="https://10.64.146.96/grafana/d/yAFWGA7mk/home-ps-core?refresh=5m&orgId=1"
t=2018-07-05T05:52:32+0000 lvl=info msg="Request Completed" logger=context userId=6 orgId=1 uname=fopscore method=GET path=/api/login/ping status=401 remote_addr=172.19.0.1 time_ms=2 size=26 referer="https://10.64.146.96/grafana/d/yAFWGA7mk/home-ps-core?refresh=5m&orgId=1"
t=2018-07-05T05:52:32+0000 lvl=info msg="Request Completed" logger=context userId=6 orgId=1 uname=fopscore method=GET path=/api/login/ping status=401 remote_addr=172.19.0.1 time_ms=21 size=26 referer="https://10.64.146.96/grafana/d/yAFWGA7mk/home-ps-core?refresh=5m&orgId=1"
t=2018-07-05T05:52:32+0000 lvl=info msg="Database table locked, sleeping then retrying" logger=sqlstore retry=1
t=2018-07-05T05:52:32+0000 lvl=info msg="Database table locked, sleeping then retrying" logger=sqlstore retry=2
Thanks,
Heri
