Hi all,
- I have added a custom dashboard to grafana through Import JSON. I can see the dashboard on my UI but i am not able to find it in /etc/grafana/dashboards?where can I locate it?
Thanks,
Shankar.
Hi all,
Thanks,
Shankar.
Hello @shankarpentyala and to anybody that might be having the same question at the present time.
The location of the folder containing the dashboard .json file will vary depending on the OS you run Grafana on. In addition, we would need to know the exact steps taken during the installation in order to provide you with an answer.
Hi there!
When you import a dashboard via the Grafana UI using the Import JSON feature, it doesn’t directly save the dashboard JSON to the file system (like /etc/grafana/dashboards). Instead, it is stored in Grafana’s database.
To locate the dashboard:
If you’re using file-based provisioning for dashboards (which is typically stored in /etc/grafana/dashboards), dashboards added via the import process won’t show up in that directory unless explicitly saved there.
To locate dashboards that are part of your file-based provisioning, you’d need to check the configuration in the grafana.ini file and ensure the dashboard folder path is correctly specified.
Let me know if you need any more help!
