This is the log before hitting “Test Connection” in mysql data source setting:
pdc.exe -log.level=debug -token <my token> -cluster prod-ap-south-0 -gcloud-hosted-grafana-id 744478 -ssh-flag='-o PermitRemoteOpen=localhost:3306'
level=info caller=main.go:109 ts=2024-03-01T14:39:48.437305+06:00 msg="PDC agent info" version=v0.0.23 commit=881abe89f842ec98b27d6bfc7371c8333c07d669 date=2023-12-18T13:52:47Z sshversion="OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2\r" os=windows arch=amd64
level=info caller=ssh.go:109 ts=2024-03-01T14:39:48.4383022+06:00 msg="starting ssh client"
level=info caller=keymanager.go:53 ts=2024-03-01T14:39:48.4388096+06:00 msg="starting key manager"
level=info caller=keymanager.go:170 ts=2024-03-01T14:39:48.4396279+06:00 msg="new certificate required: certificate validity has expired"
level=info caller=keymanager.go:243 ts=2024-03-01T14:39:48.4397858+06:00 msg="generating new certificate"
level=debug caller=client.go:227 ts=2024-03-01T14:39:48.4462155+06:00 msg="performing request" method=POST url=https://private-datasource-connect-api-prod-ap-south-0.grafana.net/pdc/api/v1/sign-public-key
level=debug caller=ssh.go:128 ts=2024-03-01T14:39:48.87051+06:00 msg="parsed flags: [-i C:\\Users\\mahin/.ssh/grafana_pdc 744478@private-datasource-connect-prod-ap-south-0.grafana.net -p 22 -R 0 -o CertificateFile=C:\\Users\\mahin/.ssh/grafana_pdc-cert.pub -o ConnectTimeout=1 -o ServerAliveInterval=15 -o UserKnownHostsFile=C:\\Users\\mahin/.ssh/grafana_pdc_known_hosts -vvv '-o]"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.8910939+06:00 msg="OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.8910939+06:00 msg="debug3: Failed to open file:C:/Users/mahin/.ssh/config error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.8917575+06:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_config error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.8953423+06:00 msg="debug2: resolving \"private-datasource-connect-prod-ap-south-0.grafana.net\" port 22"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.9586804+06:00 msg="debug2: ssh_connect_direct"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.9609392+06:00 msg="debug1: Connecting to private-datasource-connect-prod-ap-south-0.grafana.net [34.93.57.132] port 22."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:48.9614453+06:00 msg="debug2: fd 3 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9702+06:00 msg="debug1: fd 3 clearing O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9707048+06:00 msg="debug1: Connection established."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9726778+06:00 msg="debug1: identity file C:\\\\Users\\\\mahin/.ssh/grafana_pdc type 3"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9744694+06:00 msg="debug1: certificate file C:\\\\Users\\\\mahin/.ssh/grafana_pdc-cert.pub type 7"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9745246+06:00 msg="debug1: Local version string SSH-2.0-OpenSSH_for_Windows_8.1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9750898+06:00 msg="debug1: Remote protocol version 2.0, remote software version Go"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9750898+06:00 msg="debug1: no match: Go"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9755953+06:00 msg="debug2: fd 3 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.975644+06:00 msg="debug1: Authenticating to private-datasource-connect-prod-ap-south-0.grafana.net:22 as '744478'"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.975644+06:00 msg="debug3: hostkeys_foreach: reading file \"C:\\\\Users\\\\mahin/.ssh/grafana_pdc_known_hosts\""
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9761667+06:00 msg="debug3: record_hostkey: found ca key type RSA in file C:\\\\Users\\\\mahin/.ssh/grafana_pdc_known_hosts:1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9766861+06:00 msg="debug3: load_hostkeys: loaded 1 keys from private-datasource-connect-prod-ap-south-0.grafana.net"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9772112+06:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9782753+06:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts2 error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9787988+06:00 msg="debug3: send packet: type 20"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:49.9793174+06:00 msg="debug1: SSH2_MSG_KEXINIT sent"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0366757+06:00 msg="debug3: receive packet: type 20"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0519637+06:00 msg="debug1: SSH2_MSG_KEXINIT received"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0541224+06:00 msg="debug2: local client KEXINIT proposal"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0546897+06:00 msg="debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0599325+06:00 msg="debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0605334+06:00 msg="debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0611859+06:00 msg="debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0622629+06:00 msg="debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0628846+06:00 msg="debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0628846+06:00 msg="debug2: compression ctos: none,zlib@openssh.com,zlib"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0640231+06:00 msg="debug2: compression stoc: none,zlib@openssh.com,zlib"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0645791+06:00 msg="debug2: languages ctos: "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0651342+06:00 msg="debug2: languages stoc: "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0656858+06:00 msg="debug2: first_kex_follows 0 "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0662489+06:00 msg="debug2: reserved 0 "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0668295+06:00 msg="debug2: peer server KEXINIT proposal"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0743076+06:00 msg="debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,kex-strict-s-v00@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0755983+06:00 msg="debug2: host key algorithms: rsa-sha2-256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0755983+06:00 msg="debug2: ciphers ctos: aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0772157+06:00 msg="debug2: ciphers stoc: aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0772157+06:00 msg="debug2: MACs ctos: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0772157+06:00 msg="debug2: MACs stoc: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0772157+06:00 msg="debug2: compression ctos: none"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0772157+06:00 msg="debug2: compression stoc: none"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0803286+06:00 msg="debug2: languages ctos: "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0814101+06:00 msg="debug2: languages stoc: "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0819492+06:00 msg="debug2: first_kex_follows 0 "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0824765+06:00 msg="debug2: reserved 0 "
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.083148+06:00 msg="debug1: kex: algorithm: curve25519-sha256"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0910118+06:00 msg="debug1: kex: host key algorithm: rsa-sha2-512-cert-v01@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0929649+06:00 msg="debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0935293+06:00 msg="debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0952221+06:00 msg="debug3: send packet: type 30"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.0962648+06:00 msg="debug1: expecting SSH2_MSG_KEX_ECDH_REPLY"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2527846+06:00 msg="debug3: receive packet: type 31"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2549573+06:00 msg="debug1: Server host certificate: ssh-rsa-cert-v01@openssh.com SHA256:JYZn+FpH6nXKlbBT4ER1lmiaEhzyC6zdAkUEF+hqOI8, serial 0 ID \"\" CA ssh-rsa SHA256:7Mrj7jER3YBUy5LsAL9gMiCE6v6aYFSTzRHye20AL8w valid forever"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2600488+06:00 msg="debug2: Server host certificate hostname: private-datasource-connect-prod-ap-south-0.grafana.net"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2605983+06:00 msg="debug3: hostkeys_foreach: reading file \"C:\\\\Users\\\\mahin/.ssh/grafana_pdc_known_hosts\""
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2617383+06:00 msg="debug3: record_hostkey: found ca key type RSA in file C:\\\\Users\\\\mahin/.ssh/grafana_pdc_known_hosts:1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2622971+06:00 msg="debug3: load_hostkeys: loaded 1 keys from private-datasource-connect-prod-ap-south-0.grafana.net"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2628607+06:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2634673+06:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts2 error:2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2646144+06:00 msg="debug1: Host 'private-datasource-connect-prod-ap-south-0.grafana.net' is known and matches the RSA-CERT host certificate."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2651641+06:00 msg="debug1: Found CA key in C:\\\\Users\\\\mahin/.ssh/grafana_pdc_known_hosts:1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2776844+06:00 msg="debug3: send packet: type 21"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2776844+06:00 msg="debug2: set_newkeys: mode 1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2787836+06:00 msg="debug1: rekey out after 134217728 blocks"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2805897+06:00 msg="debug1: SSH2_MSG_NEWKEYS sent"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2811236+06:00 msg="debug1: expecting SSH2_MSG_NEWKEYS"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2820043+06:00 msg="debug3: receive packet: type 21"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2825461+06:00 msg="debug1: SSH2_MSG_NEWKEYS received"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2830888+06:00 msg="debug2: set_newkeys: mode 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2841652+06:00 msg="debug1: rekey in after 134217728 blocks"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2848246+06:00 msg="debug3: unable to connect to pipe \\\\\\\\.\\\\pipe\\\\openssh-ssh-agent, error: 2"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2864585+06:00 msg="debug1: pubkey_prepare: ssh_get_authentication_socket: No such file or directory"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2930971+06:00 msg="debug1: Will attempt key: C:\\\\Users\\\\mahin/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:eN9i9NLI8B/6MEPmi/T72UEQkiDz28wBB3ntf+1n3hE explicit"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2976628+06:00 msg="debug1: Will attempt key: C:\\\\Users\\\\mahin/.ssh/grafana_pdc ED25519 SHA256:eN9i9NLI8B/6MEPmi/T72UEQkiDz28wBB3ntf+1n3hE explicit"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2982389+06:00 msg="debug2: pubkey_prepare: done"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.2999574+06:00 msg="debug3: send packet: type 5"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.3006118+06:00 msg="debug3: receive packet: type 7"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.3006118+06:00 msg="debug1: SSH2_MSG_EXT_INFO received"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.3095704+06:00 msg="debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,rsa-sha2-256,rsa-sha2-512,ssh-rsa,ssh-dss>"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.3121157+06:00 msg="debug1: kex_input_ext_info: ping@openssh.com (unrecognised)"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.4697361+06:00 msg="debug3: receive packet: type 6"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.4725292+06:00 msg="debug2: service_accept: ssh-userauth"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.4744459+06:00 msg="debug1: SSH2_MSG_SERVICE_ACCEPT received"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.4750559+06:00 msg="debug3: send packet: type 50"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.536384+06:00 msg="debug3: receive packet: type 51"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5578091+06:00 msg="debug1: Authentications that can continue: publickey"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5583639+06:00 msg="debug3: start over, passed a different list publickey"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5594681+06:00 msg="debug3: preferred publickey,keyboard-interactive,password"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5600092+06:00 msg="debug3: authmethod_lookup publickey"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5605695+06:00 msg="debug3: remaining preferred: keyboard-interactive,password"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5610731+06:00 msg="debug3: authmethod_is_enabled publickey"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5617464+06:00 msg="debug1: Next authentication method: publickey"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5623497+06:00 msg="debug1: Offering public key: C:\\\\Users\\\\mahin/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:eN9i9NLI8B/6MEPmi/T72UEQkiDz28wBB3ntf+1n3hE explicit"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5628752+06:00 msg="debug3: send packet: type 50"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.5633995+06:00 msg="debug2: we sent a publickey packet, wait for reply"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.6366069+06:00 msg="debug3: receive packet: type 60"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.6448742+06:00 msg="debug1: Server accepts key: C:\\\\Users\\\\mahin/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:eN9i9NLI8B/6MEPmi/T72UEQkiDz28wBB3ntf+1n3hE explicit"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.6449352+06:00 msg="debug3: sign_and_send_pubkey: ED25519-CERT SHA256:eN9i9NLI8B/6MEPmi/T72UEQkiDz28wBB3ntf+1n3hE"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.649776+06:00 msg="debug2: sign_and_send_pubkey: using private key \"C:\\\\Users\\\\mahin/.ssh/grafana_pdc-cert.pub\" for certificate"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.6503359+06:00 msg="debug3: sign_and_send_pubkey: signing using ssh-ed25519-cert-v01@openssh.com"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.6537087+06:00 msg="debug3: send packet: type 50"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7198008+06:00 msg="debug3: receive packet: type 52"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7313969+06:00 msg="debug1: Authentication succeeded (publickey)."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7333875+06:00 msg="Authenticated to private-datasource-connect-prod-ap-south-0.grafana.net ([34.93.57.132]:22)."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7391939+06:00 msg="debug1: Remote connections from LOCALHOST:0 forwarded to local address socks:0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7391939+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7405246+06:00 msg="debug2: fd 5 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7410954+06:00 msg="debug2: fd 6 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7418016+06:00 msg="debug1: channel 0: new [client-session]"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7423667+06:00 msg="debug3: ssh_session2_open: channel_new: 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.742924+06:00 msg="debug2: channel 0: send open"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7434474+06:00 msg="debug3: send packet: type 90"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7445289+06:00 msg="debug1: Entering interactive session."
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.7450572+06:00 msg="debug1: pledge: network"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.8451784+06:00 msg="debug3: receive packet: type 81"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.8453777+06:00 msg="debug1: remote forward success for: listen 0, connect socks:0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.8468383+06:00 msg="Allocated port 1234 for remote forward to socks:0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.8475068+06:00 msg="debug1: Updating allowed port 1234 for forwarding to host socks port 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.8532069+06:00 msg="debug1: All remote forwarding requests processed"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9199558+06:00 msg="debug3: receive packet: type 91"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9216862+06:00 msg="debug2: channel_input_open_confirmation: channel 0: callback start"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9228033+06:00 msg="debug2: fd 3 setting TCP_NODELAY"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9280071+06:00 msg="debug2: client_session2_setup: id 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9285454+06:00 msg="debug1: Sending command: '-o"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9292174+06:00 msg="debug2: channel 0: request exec confirm 1"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.929778+06:00 msg="debug3: send packet: type 98"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9303437+06:00 msg="debug2: channel_input_open_confirmation: channel 0: callback done"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:50.9309625+06:00 msg="debug2: channel 0: open confirm rwindow 2097152 rmax 32768"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:51.0074733+06:00 msg="debug3: receive packet: type 99"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:51.0074733+06:00 msg="debug2: channel_input_status_confirm: type 99 id 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:51.0142266+06:00 msg="debug2: exec request accepted on channel 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:39:51.0147958+06:00 msg="This is Grafana Private Datasource Connect!\n"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:06.0305082+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:06.1046814+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:21.1080637+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:21.1850102+06:00 msg="debug3: receive packet: type 82"
(PDC config page in grafana says: 1 agent connected.)
The following log is after clicking Save and Test in ‘data source’ error: driver: bad connection.
I dont now what is going on but it seems like I am getting this erorr socketio shutdown - ERROR:10057. Any idea whats wrong? My firewall is turned off.
level=info caller=ssh.go:276 ts=2024-03-01T14:40:36.1869079+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:41.2049232+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:51.5697391+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:40:51.6460165+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:06.6549873+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:06.7314664+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:21.7336381+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:21.8101326+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:36.8113025+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:36.8871071+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:51.8896258+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:41:51.9542053+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:06.9812581+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:07.0486535+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:22.0753551+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:22.1515694+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1721844+06:00 msg="debug3: receive packet: type 90"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1749714+06:00 msg="debug1: client_input_channel_open: ctype forwarded-tcpip rchan 1 win 2097152 max 32768"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1798162+06:00 msg="debug1: client_request_forwarded_tcpip: listen localhost port 1234, originator 1.2.3.4 port 4567"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1803753+06:00 msg="debug1: channel 1: new [1.2.3.4]"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.180936+06:00 msg="debug1: confirm forwarded-tcpip"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1820622+06:00 msg="debug3: send packet: type 91"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1826818+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:31.1837507+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.2438992+06:00 msg="debug2: channel 1: pre_rdynamic: have 4"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.2438992+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.2462227+06:00 msg="debug2: channel 1: socks5 auth done"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.2462775+06:00 msg="debug2: channel 1: pre_rdynamic: need more"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.2513236+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7391706+06:00 msg="debug2: channel 1: pre_rdynamic: have 16"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7485608+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7504922+06:00 msg="debug2: channel 1: socks5 post auth"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7510016+06:00 msg="debug2: channel 1: dynamic request: socks5 host localhost port 3306 command 1"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7570224+06:00 msg="debug2: fd 7 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7587918+06:00 msg="debug3: socketio_getsockopt - ERROR:10022"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7594232+06:00 msg="debug1: getsockopt TCP_NODELAY: Invalid argument"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7605313+06:00 msg="debug1: connect_next: host localhost ([::1]:3306) in progress, fd=7"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7610369+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7616278+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:32.7622874+06:00 msg="debug3: channel 1: waiting for connection"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8043279+06:00 msg="debug3: finish_connect - ERROR: async io completed with error: 10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8045985+06:00 msg="debug1: channel 1: connected to localhost port 3306"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8112265+06:00 msg="debug3: recv - from CB ERROR:10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8112265+06:00 msg="debug2: channel 1: read<=0 rfd 7 len 4294967295"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8128731+06:00 msg="debug2: channel 1: read failed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8134278+06:00 msg="debug2: channel 1: chan_shutdown_read (i0 o0 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8139696+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8150181+06:00 msg="debug2: channel 1: input open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8156881+06:00 msg="debug2: channel 1: ibuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8162862+06:00 msg="debug2: channel 1: send eof"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8168187+06:00 msg="debug3: send packet: type 96"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8178667+06:00 msg="debug2: channel 1: input drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.887703+06:00 msg="debug3: receive packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8935178+06:00 msg="debug2: channel 1: rcvd close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8958574+06:00 msg="debug2: channel 1: output open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.8970695+06:00 msg="debug3: channel 1: will not send data after close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.901232+06:00 msg="debug2: channel 1: obuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9018035+06:00 msg="debug2: channel 1: chan_shutdown_write (i3 o1 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9023692+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9057596+06:00 msg="debug2: channel 1: chan_shutdown_write: shutdown() failed for fd 7 [i3 o1]: The socket is not connected"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9060514+06:00 msg="debug2: channel 1: output drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9068771+06:00 msg="debug2: channel 1: send close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9075973+06:00 msg="debug3: send packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9083048+06:00 msg="debug2: channel 1: is dead"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9091319+06:00 msg="debug2: channel 1: garbage collecting"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.909685+06:00 msg="debug1: channel 1: free: 1.2.3.4, nchannels 2"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9103342+06:00 msg="debug3: channel 1: status: The following connections are open:"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9108678+06:00 msg=" #0 client-session (t4 r0 i0/0 o0/0 e[write]/0 fd 4/5/6 sock -1 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:34.9114781+06:00 msg=" #1 1.2.3.4 (t4 r1 i3/0 o3/0 e[closed]/0 fd 7/7/-1 sock 7 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.2993166+06:00 msg="debug3: receive packet: type 90"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.2993166+06:00 msg="debug1: client_input_channel_open: ctype forwarded-tcpip rchan 2 win 2097152 max 32768"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3011894+06:00 msg="debug1: client_request_forwarded_tcpip: listen localhost port 1234, originator 1.2.3.4 port 4567"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3064895+06:00 msg="debug1: channel 1: new [1.2.3.4]"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3070277+06:00 msg="debug1: confirm forwarded-tcpip"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3082024+06:00 msg="debug3: send packet: type 91"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3087541+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3098799+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.370766+06:00 msg="debug2: channel 1: pre_rdynamic: have 4"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3853633+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.391752+06:00 msg="debug2: channel 1: socks5 auth done"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3923251+06:00 msg="debug2: channel 1: pre_rdynamic: need more"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.3934623+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4543146+06:00 msg="debug2: channel 1: pre_rdynamic: have 16"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4700016+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4702868+06:00 msg="debug2: channel 1: socks5 post auth"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4744454+06:00 msg="debug2: channel 1: dynamic request: socks5 host localhost port 3306 command 1"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4761507+06:00 msg="debug2: fd 7 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4767078+06:00 msg="debug3: socketio_getsockopt - ERROR:10022"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4767078+06:00 msg="debug1: getsockopt TCP_NODELAY: Invalid argument"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4778802+06:00 msg="debug1: connect_next: host localhost ([::1]:3306) in progress, fd=7"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4784405+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4790008+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:35.4795565+06:00 msg="debug3: channel 1: waiting for connection"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5193972+06:00 msg="debug3: finish_connect - ERROR: async io completed with error: 10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5198519+06:00 msg="debug1: channel 1: connected to localhost port 3306"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5227941+06:00 msg="debug3: recv - from CB ERROR:10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5228545+06:00 msg="debug2: channel 1: read<=0 rfd 7 len 4294967295"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5280864+06:00 msg="debug2: channel 1: read failed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5291148+06:00 msg="debug2: channel 1: chan_shutdown_read (i0 o0 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5291148+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5297733+06:00 msg="debug2: channel 1: input open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5307171+06:00 msg="debug2: channel 1: ibuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5313042+06:00 msg="debug2: channel 1: send eof"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5318247+06:00 msg="debug3: send packet: type 96"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.5323873+06:00 msg="debug2: channel 1: input drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6030267+06:00 msg="debug3: receive packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6104618+06:00 msg="debug2: channel 1: rcvd close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6104618+06:00 msg="debug2: channel 1: output open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6157132+06:00 msg="debug3: channel 1: will not send data after close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6162789+06:00 msg="debug2: channel 1: obuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6168112+06:00 msg="debug2: channel 1: chan_shutdown_write (i3 o1 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6173754+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6212737+06:00 msg="debug2: channel 1: chan_shutdown_write: shutdown() failed for fd 7 [i3 o1]: The socket is not connected"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6236279+06:00 msg="debug2: channel 1: output drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6241944+06:00 msg="debug2: channel 1: send close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6291347+06:00 msg="debug3: send packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6291347+06:00 msg="debug2: channel 1: is dead"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6306802+06:00 msg="debug2: channel 1: garbage collecting"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6311884+06:00 msg="debug1: channel 1: free: 1.2.3.4, nchannels 2"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6319506+06:00 msg="debug3: channel 1: status: The following connections are open:"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6320896+06:00 msg=" #0 client-session (t4 r0 i0/0 o0/0 e[write]/0 fd 4/5/6 sock -1 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6326227+06:00 msg=" #1 1.2.3.4 (t4 r2 i3/0 o3/0 e[closed]/0 fd 7/7/-1 sock 7 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6441113+06:00 msg="debug3: receive packet: type 90"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6452522+06:00 msg="debug1: client_input_channel_open: ctype forwarded-tcpip rchan 1 win 2097152 max 32768"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6463809+06:00 msg="debug1: client_request_forwarded_tcpip: listen localhost port 1234, originator 1.2.3.4 port 4567"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6471563+06:00 msg="debug1: channel 1: new [1.2.3.4]"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6477357+06:00 msg="debug1: confirm forwarded-tcpip"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6482895+06:00 msg="debug3: send packet: type 91"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6489171+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.6501899+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.720034+06:00 msg="debug2: channel 1: pre_rdynamic: have 4"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.7254549+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.7270735+06:00 msg="debug2: channel 1: socks5 auth done"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.7316884+06:00 msg="debug2: channel 1: pre_rdynamic: need more"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.7333531+06:00 msg="debug2: channel 1: pre_rdynamic: have 0"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.803395+06:00 msg="debug2: channel 1: pre_rdynamic: have 16"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8099654+06:00 msg="debug2: channel 1: decode socks5"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8099654+06:00 msg="debug2: channel 1: socks5 post auth"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8148666+06:00 msg="debug2: channel 1: dynamic request: socks5 host localhost port 3306 command 1"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8157012+06:00 msg="debug2: fd 7 setting O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8170604+06:00 msg="debug3: socketio_getsockopt - ERROR:10022"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8177324+06:00 msg="debug1: getsockopt TCP_NODELAY: Invalid argument"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8184138+06:00 msg="debug1: connect_next: host localhost ([::1]:3306) in progress, fd=7"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8273509+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8278589+06:00 msg="debug3: fd 7 is O_NONBLOCK"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:37.8284845+06:00 msg="debug3: channel 1: waiting for connection"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8516045+06:00 msg="debug3: finish_connect - ERROR: async io completed with error: 10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8545903+06:00 msg="debug1: channel 1: connected to localhost port 3306"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8545903+06:00 msg="debug3: recv - from CB ERROR:10061, io:000002B168607E10"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8594237+06:00 msg="debug2: channel 1: read<=0 rfd 7 len 4294967295"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8602876+06:00 msg="debug2: channel 1: read failed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8609829+06:00 msg="debug2: channel 1: chan_shutdown_read (i0 o0 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8618834+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8625126+06:00 msg="debug2: channel 1: input open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8630441+06:00 msg="debug2: channel 1: ibuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8636539+06:00 msg="debug2: channel 1: send eof"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.8641767+06:00 msg="debug3: send packet: type 96"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.864848+06:00 msg="debug2: channel 1: input drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9410561+06:00 msg="debug3: receive packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9410561+06:00 msg="debug2: channel 1: rcvd close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9431136+06:00 msg="debug2: channel 1: output open -> drain"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9482733+06:00 msg="debug3: channel 1: will not send data after close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.94885+06:00 msg="debug2: channel 1: obuf empty"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9500123+06:00 msg="debug2: channel 1: chan_shutdown_write (i3 o1 sock 7 wfd 7 efd -1 [closed])"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9505701+06:00 msg="debug3: socketio_shutdown - ERROR:10057"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9586531+06:00 msg="debug2: channel 1: chan_shutdown_write: shutdown() failed for fd 7 [i3 o1]: The socket is not connected"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9592207+06:00 msg="debug2: channel 1: output drain -> closed"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9601396+06:00 msg="debug2: channel 1: send close"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9607074+06:00 msg="debug3: send packet: type 97"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9612969+06:00 msg="debug2: channel 1: is dead"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9622697+06:00 msg="debug2: channel 1: garbage collecting"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9627759+06:00 msg="debug1: channel 1: free: 1.2.3.4, nchannels 2"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9634167+06:00 msg="debug3: channel 1: status: The following connections are open:"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9641354+06:00 msg=" #0 client-session (t4 r0 i0/0 o0/0 e[write]/0 fd 4/5/6 sock -1 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:39.9646444+06:00 msg=" #1 1.2.3.4 (t4 r1 i3/0 o3/0 e[closed]/0 fd 7/7/-1 sock 7 cc -1)"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:54.9773181+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:42:55.0532086+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:10.0729546+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:10.4505359+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:25.467107+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:25.8341197+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:40.8447203+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:40.9114072+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:43:55.9217633+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:44:10.5822411+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:44:11.016089+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:44:11.0825267+06:00 msg="debug3: receive packet: type 82"
level=info caller=ssh.go:276 ts=2024-03-01T14:44:26.0922518+06:00 msg="debug3: send packet: type 80"
level=info caller=ssh.go:276 ts=2024-03-01T14:44:26.7763459+06:00 msg="debug3: receive packet: type 82"
