Sadly, it still does not work. Seems like an issue with the YAML file or something in config
Dec 30 17:40:00 syslog2 grafana-agent[2668]: ts=2023-12-30T17:40:00.905402197Z caller=manager.go:261 level=error msg="failed to initialize integration. it will not run or be scraped" integration=snmp err="failed to load snmp config from file /etc/ubnt_router.yml: yaml: unmarshal errors:\n line 2: field ubnt_router not found in type config.Config"
No matter what I do, it won’t start w/o errors if i point to the YML file.
