I’m trying to get the grafana agent to work with the SNMP instructions for Ubiquiti edgerrouter.
I try to use the SNMP referenced at jsonnet-libs/ubnt-edgerouter-mixin/snmp_generator/snmp.yml at master · grafana/jsonnet-libs · GitHub and put that in a file (/etc/snmp.yml), then update the grafana-config.yml to look like:
snmp:
enabled: true
config_file: '/etc/snmp.yml'
snmp_targets:
- name: router_1
address: '<router_1_address>'
module: ubnt_router
walk_params: ubnt_router
walk_params:
ubnt_router:
version: 2
auth:
community: public
relabel_configs:
- replacement: integrations/ubiquiti-edgerouter
target_label: job
metric_relabel_configs:
- action: keep
But everytime the agent fails will messages like:
integration=snmp err="failed to load snmp config from file /etc/snmp.yml: yaml: unmarshal errors:\n line 1: field ubnt_router not found in type config.Config"
Not sure what I’m doing wrong, and any help would be appreciated.
