kevint
June 11, 2023, 8:59am
1
I try to display my data from influxDB. Finally I managed to design my query. What I did not achieve is to display two queries in one bar chart.
first query:
import "date"
from(bucket: "iobroker")
|> filter(fn: (r) => r._measurement == "openknx.0._BC__Buero_Christian.Verbraucher._BC__Ver___PC_-_Wirkleistung" and r._field == "value")
|> map(fn: (r) => ({r with hour: date.hour(t: r._time) } ))
|> group(columns: ["hour"], mode:"by")
|> mean()
|> group()
|> sort(columns:["hour"])
|> map(fn: (r) => ({r with hour_txt: string(v: r.hour)}))
|> drop(columns: ["hour"])
|> yield(name:"PC CH")
second query:
import "date"
|> filter(fn: (r) => r._measurement == "openknx.0._BT__Buero_Tinka.Verbraucher._BT__Ver___PC_-_Wirkleistung" and r._field == "value")
|> mean()
|> group()
|> yield(name: "PC TI")
As soon as I disable one of the queries the other one will be displayed.
What am I doing wrong?
Best regards,
Kevin
grant2
June 11, 2023, 8:38pm
2
Hi @kevint
Looks like you have two different measurements, but the rest of the fields / tags are the same. Is that correct? If yes, simply separate the two measurements with or like this:
import "date"
|> filter(fn: (r) => r._measurement == "openknx.0._BC__Buero_Christian.Verbraucher._BC__Ver___PC_-_Wirkleistung" or r._measurement == "openknx.0._BT__Buero_Tinka.Verbraucher._BT__Ver___PC_-_Wirkleistung")
|> filter(fn: (r) => r["_field"] == "value")
|> mean()
|> group()
kevint
June 12, 2023, 6:04pm
3
Hi @grant2 ,
you are right. Those are different measurements with identical tags, but wouldn`t your solution result in one graph instead of two separate ones?
grant2
June 13, 2023, 9:50am
4
Hi @kevint Yes, you should get one graph, which I thought was your goal when you wrote “display two queries in one bar chart”.
Did you try this yet in Grafana, and if yes, what was the result?
kevint
June 13, 2023, 4:46pm
5
Hi @grant2 ,
I did try it but couldn’t understand it at first as I had a mistake in my query. It should be sum() after the grouping, not mean().
Now it is as expected: The sum of both values:
What I would like to have is bars in one bar chart:
kevint
June 14, 2023, 7:04pm
6
I solved my issue within flux.
Now my code looks like this:
import "date"
|> filter(fn: (r) => r["_measurement"] == "openknx.0._BC__Buero_Christian.Verbraucher._BC__Ver___PC_-_Wirkleistung" or r["_measurement"] == "openknx.0._BT__Buero_Tinka.Verbraucher._BT__Ver___PC_-_Wirkleistung")
|> group(columns: ["_measurement","hour"], mode:"by")
|> sum()
|> group()
|> pivot(rowKey: ["hour_txt"], columnKey:["_measurement"], valueColumn:"_value")
I still dont understand why using two queries did not work.
