How to addion 2 Values? (solved)
have a influx DB and wann addion 2 Values
Here are the 2 Querys
from(bucket: “iobroker”)
|> filter(fn: (r) => r[“_measurement”] == “panel1”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”)
|> filter(fn: (r) => r[“_measurement”] == “panel2”)
|> yield(name: “mean”)
Wanna get panel1+panel2
Thanks
you can use two queries in the same panel, and then use a add field from calculation transformation to sum them
thanks found it
grafik
