Is there a simple way to do addition between 2 different sources. I did 2 queries as shown down below and somehow I’d like to add both SELECT last(“df_complex.used”) FROM “mnt-MediaPool-Media-Movies” and SELECT last(“df_complex.used”) FROM “mnt-MediaPool-Media-TVShows”
> select * from "mnt-MediaPool-Media-Movies" LIMIT 1
time df_complex.free df_complex.reserved df_complex.used host resource
1598650165000000000 2743866245120 0 475488329728 truenas_local df
> select * from "mnt-MediaPool-Media-TVShows" LIMIT 1
1598650165000000000 2743866245120 0 529429798912 truenas_local df
In Grafana, I know that I can do simple addition operation query like this from the same source but not with 2 or more different sources. Is there a way or I have to add variable for each different source? Thanks in advance
SELECT last("df_complex.free") + last("df_complex.used") FROM "mnt-MediaPool-Media-Movies"
