I am using managed Grafana in the cloud. - What are you trying to achieve?
I am having two queries that are showing two different values in one time-series graph. Data source is influx db. I can not get sum in influx, because measurements are not done in completely the same _time (in the same second) - How are you trying to achieve it?
I already tried to create new query and use $A+$B, but without success.
In the above screen, you will see, I have a value of 3 and value of 18, I would also like to have a line with value 21, that will represent the sum. How is this possible?
