I’m logging several measurements. For each value there are many entries per hour.
Now I want to have a bar chart which shows my the average for each value for one hour, the chat should show e.g. the last 12 hours.
the query looks like this:
from(bucket: “iobroker”)
|> filter(fn: (r) => r[“_measurement”] == “0_userdata.0.PV_Produktion”
or r[“_measurement”] == “0_userdata.0.PV_Eigenverbrauch”
or r[“_measurement”] == “0_userdata.0.PV_Netzbezug”
or r[“_measurement”] == “0_userdata.0.PV_Wallbox”
or r[“_measurement”] == “0_userdata.0.PV_Nur_Einspeisung”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
The bars for each hour are show at one place. Stacking is set to none. I tried several hints, but I didn’t manage to show the bars side by side.
What is wrong?
Tried it with a new panel, only 2 values, split the query in separate queries etc. Nothing helped
