Hey,
I tried the elasticsearch dashboard 878 with grafana. I added a datasource to my cluster, which is running elasticsearch 5.4 and the save+test button shows green so far. I’m running grafana with the default sqlite DB. After importing the dashboard, I get the error below on every item in the board. Neither my cluster nor node-names contain any “-” chars and I’m kinda stuck where to look next. Does anyone have an idea what may cause this problem?
"root_cause": [
"type": "parse_exception",
"reason": "parse_exception: Encountered \"\" at line 1, column 13.
Was expecting one of:
"type": "search_phase_execution_exception",
"reason": "all shards failed",
"phase": "query",
"grouped": true,
"failed_shards": [
"shard": 0,
"index": "bla.blub-1",
"node": "l_XKqxlMQ2tXMk4vUocANw",
"reason": {
"type": "query_shard_exception",
"reason": "Failed to parse query [cluster_name:]",
"index_uuid": "okvqdJHqWi-Uesnd6k0hTw",
"caused_by": {
"reason": "parse_exception: Cannot parse 'cluster_name:': Encountered \"\" at line 1, column 13.
"caused_by": {
Another question I have is towards the mentioned python script. As far as I understand, grafana gets the elasticsearch metrics from the saved datasource. The description is:
“The below python or powershell script, will collect the metrics from the Elasticsearch API based on the interval set and publish the data to Elasticsearch”.
Does this mean I have to run this script additionally to grafana? And why is it storing the metrics in elasticsearch at all? Or is it the other way around and the python script is collecting while the datasource is where the data for grafana is supposed to be stored?
If I want to run this script, is there a option in grafana to import said script or do I have to create a cronjob to have it periodically executed?
Thanks for any input ![]()
