Resolved, i missed a wildcard * in index name (it changed after some hours)
Hi! I have a rocky linux machine with Graylog and grafana on board.
I installed the last version of grafana. It worked well with elasticsearch data source for about six hours, and suddenly stopped collecting data.
I rebooted, i created again dashboard and data source. I uninstalled and re installaed the grafana previuos version. I created again datasource and dashboard but no data is collected. Where is the issue?
I thank You very much
Sara
What happened?
