Hi all,
I have a problem, where graphfana is taking data from a datasource other than the configured one
Has anyone ever had this problem?
Elasticsearch 6.8 version
Hi all,
How many data sources do you have configured, and what are they called?
Is any of them identified as the “default”? If so, which name?
What data source name are you using in your queries?
What does the Query Inspector tell you it is actually doing for a query
which goes to the wrong source?
Which version of Grafana are you using, and on which Operating System?
Antony.
Hi Pool, thank you so much for the response ,
A: Two, from a 2 index different
A: The datasource and the index has a different name.
A: Elasticsearch/ Logstash
A: I have added a Elasticsearch data source and works fine, but when i try add a new data source for a different index, are showing the data from the first index that i have added
A: Grafana v6.1.6 (cf9cb45) / Rhel 7.5
