Hi guys,
not sure if the ‘Query from config result’ option that is found under the ‘Transform’ tab for the panels is designed for one use only?
Right now if I have an instance of the ‘config from query result’ configured and I go on to add another one. It adds but the Config query dropdown box will be blank. Unlike the first instance’s.
I think this is a bug but I thought I’ll ask first. It is pretty easy to replicate it, just head to the ‘Query from config’ example on play.grafana and add another one.
Is this behaviour expected? I have tried it on 8.5.0 seems to be the same aso.
