Transform - Rename By Regex
mssu_12345_FailCode_PROPANE_FAIL_AwaitingDocumentsFromCounterparty_GB{instance=“XX-de5a-XXYY.abc.nsroot.net:33581”, job=“MssuExporter”}
I have this metric coming in via Prometheus. I just want to display “AwaitingDocumentsFromCounterparty” as the name if the metric
Tried using transform - Rename by Regex.
Match : .*(FAIL)
Replace : left as blank
gives me “AwaitingDocumentsFromCounterparty_GB{instance=“XX-de5a-XXYY.abc.nsroot.net:33581”, job=“MssuExporter”}” .
Just want “AwaitingDocumentsFromCounterparty”
what if you just use AwaitingDocumentsFromCounterparty in the regex? or are there other flavors
Thank You for the response
cant, i will be pulling 120 metrics and each of them will have a different fail code . am looking for code that can only extract that subset of characters after the string FAIL, so that i don’t have to repeat the code 120 times
Wouldn’t something like
(.*)_FAIL_(.*?)_(.*) work (with replacement $2)? The (.*?) means “take as little as possible”
Thank You . This works
Is there a way i can achieve this using only Match and not giving anything in replace
The reason i ask is, i have to use a similar regex in the Variables to provide a filter/drop down with all the available error codes
Under Dashboard Settings–Variables–Edit , i only see a Regex option and no Match and replace
I’m not sure (you’ll have to test it for your example) but I think the same regex would work without parenthesis in the first group.
.*_FAIL_(.*?)_(.*)
Regex’s not my specialty, so I don’t know either what happens, but it worked for me :smile:
Thank You. This worked perfectly fine
