I am using Grafana v9.0.6 installed via docker on amazon linux -
I would like to convert the name of my metric to to remove the redundant portion for display in the legend. -
using “rename by regex” transform -
What happened?
specifying the redundant string as “Match” and replacing with some other string has no effect. In fact, no label value at all seems to be changed. It seems the feature is not working, or, more likely, I’m grossly misunderstanding something. I am specifically using the debug mechanism to observe the transformation, but nothing changes. -
I expect if I give string “this_long_thing_should_disappear” as Match and “foo” as Replace, the former should change to the latter for all labels (including__name__) in the debug panel. -
I have also attempted to demonstrate that rename by regex works at all by using a string (“Join”) as match and “foo” as replace, as this string occurs in other label values, but I still see no effect.
no -
Transform data | Grafana documentation
I would note that this documentation is unclear (to my newb understanding) on what is subject to transformation – “parts of the query results” is vague.
p.s. one could argue that I should transform my metric name with relabelling in prometheus, and in fact I probably will do this, but I’d really like to understand how to use this feature in grafana.
