Transform data - Rename fields by regex
Version: Grafana v11.2.2+security-01 (dc86a9eafb)
what is the correct match to rename:
kostal-piko-ba.0.Power.AC1Voltage
kostal-piko-ba.0.Power.AC2Voltage
kostal-piko-ba.0.Power.AC3Voltage
to
L1
L2
L3
I try:
Match: /kostal-piko-ba.0.Power.AC(\d)Voltage/
Replace: L$1
but nothing happens.
Best regards
Marco
Welcome @marcofischerhessberg to the Grafana forum.
I believe the dot . is a special character in regex that matches any single character. To match a literal dot, I believe you might need to escape it using a backslash \. So, \. matches a literal “.”.
Does this work?
Match: /kostal-piko-ba\.0\.Power\.AC(\d)Voltage/
Replace: L$1
Hello grant2,
thanks for your reply.
Unfortunately no effect:
I noticed from your screenshot above that you have the word “value” at the end. Pretty sure you need to include that in your Regex.
Maybe /kostal-piko-ba\.0\.Power\.AC(\d)Voltage value/
Keep fiddling around with it. I am sure there is a way to do this.
Hello grant2,
No effect, “value” is not a part of the field name
Try Match
.*AC(\d).*
Replace
L$1
Dont think your regex needs to be so granular. Try above.
I tested this in my lab by extracting a digit from an IP address and then added your naming scheme using a replace and then doing a second replace to work with your requirement (above).
Not stating the obvious though, as your screenshot doesnt show, but confirm the transform is enabled. (number of times I forgot to re-enable in testing something). The other thing is if you have leading/trailing spaces that are not obvious.
Running Grafana 11.4
Hello russellparker,
Match: .Power.AC(\d)Voltage.
Replace: L$1
  • .* handles any prefix before Power.AC1Voltage, including “kostal-piko-ba.0”.
  • \. is used to escape dots in regex (because . matches any character).
  • (\d) captures the AC number (1, 2, 3).
  • .* at the end handles any suffix (like value) Grafana might be adding.
  • L$1 uses the captured group (1/2/3) and turns it into L1, L2, L3.
string manipulation using string function in flux is also another approach.
try doing it natively in flux language using a combination of strings.substring() function
and
strings.replace() function
|> map(fn: (r) => ({r with _value: strings.replace(v: r._value, t: "p", u: "XX", i: 2)}))
Hello infofcc3,
thanks for your replay.
Hello yosiasz,
thanks for your reply,
I will try it.
