Which version of Grafana and which operating system are you using?
Linux Rocky 9
Graphical version 10.4.8
I’m trying to sum the number of managed devices on the Fortigate. For example, there are items created in Zabbix for 10 APs managed by the firewall. I need to sum the number of devices and ebiri on the dashboard.
I’m trying data transformation in the add calculation field.
What happened?
The result multiplied several values. I did this based on the availability item of the APs.
Sum the number of devices and ebiri on the dashboard.
Can you copy/paste the settings you are having problems with?
Yes
Did you receive any errors in the Grafana UI or related logs? If so, please tell us exactly what they were.
No
No
