TLS authentication in Grafana
For additional security, I want to implement TLS mutual authentication in Grafana. Can we add this organization certificate directly in the Grafana configuration file (grafana.ini) or do we need to install it in proxy servers like NGINX or Apache?
Version: 6.74
Thanks
Grafana doesn’t support mutual TLS. You need proxy with mutual TLS in front of Grafana.
Thanks for the quick update, if I add TLS mutual authentication on NGIX (as proxy) the ssl certificate which I installed for Grafana still work?
Yes, it should, you should move the TLS configuration to nginx instead of Grafana when doing so. Grafana has an “Auth Proxy” authentication option which can be useful when you set up it behind a reverse proxy, but make sure to configure it to only listen to your reverse proxy when using it.
