Grafana v6.2.5 - What are you trying to achieve?
Graph shouldnt plot beyond 0 ,dont want to show negative values
But it plots beyond 0 even after restricting y-axis scale to 0 ,when series override option is used
It doesnt plot beyond 0 when series override option is not enabled
PFB graph with series override option enabled
PFB graph with series override option disabled
by setting y-min option to 0 under left Y axes -
What happened?
Y-axis scale is restricting to 0 but plot is going beyond 0 -
plot should be within y-axis scale -
No errors -
