9.2.4 on Raspberry -
Display rainfall with using bars, which show sum of all data within a group of measures… grouped by timestamp (sumn within one minute) -
Nothing special, and usually the display is fine -
What happened?
in special cases the bars are suddenly not looking like small needles, but very big bars.
Example shows same data, with same timespan, but moved over time -
No change in how the bars look like -
if necessary yes, how do i do that? -
no -
No.
Pictures attached show the same data and the timespan displayed in the chart is exactly the same. First picture shows the raindata in the middle of the chart.
Second picture shows same data at left side of the chart.
Third picture same… except that i did move the time-window few minutes forward.
Fourth picture the same… again moved for 2 minutes forward.
