9.1.6 -
Time series bar graph -
Bra graph panel -
What happened?
Data is 5 minute but display over > 1 hour. See panel snips below. The one on the left displays correctly. the one of the right spreads the column over > 1 hour. All data is 5 min. -
5 minute data view as per other panels -
No errors -
