To display the time series panel for a range over 24 hours -
Simply changing the time range -
What happened?
When the time range is > 24 Hours the data is al distorted and no continuous graph is visible. However for range <=24 Hour the graph looks ok. Is this something to do with data size or others ?
For time range > 24 Hours, The graphs should still look ok/
No error message -
