Dear Grafana,
I have installed the 6.3.1 version and linked the dashboard with a MSSQL database. My problem is that time zone is not displayed correctly. I live in Romania so time zone is UTC+2h. However, for some reason, when I select the Romanian time-zone in Grafana (or the browser timezone) the data is displayed with additional 2h shift over the correct timing (UTC+4h). On the other hand, if I select the visualization time-range (e.g. data from last 6 hours) the window of the chart is correctly set… but consequently, 2 hours of data are hidden.
Please support
Thank you very much
Sebastian Olteanu
