- Grafana v12.3.1 (3a1c80ca7c)
- I have a query which gives me the power grid prices (historical and future). I want to plot a time series chart that shows the prices from 12h in the past until 24h in the future.
- My query returns the columns “time” and “value”. Using Explore in Grafana and setting the time picker to now-12h to now +24h it perfectly works and shows the correct graph. The tricky part is when I create the panel in my dashboard. Since my other panels use another relative time, I need to hardcode the required timespan in the query options. I did: Relative Time +36h, Time Shift 12h (which effectively means -12h).
What happened?
Looking at the table the query returns the same results as in Explore before. However, the graph is not being plotted. Thats how it looks like:
If I turn it into a bar chart the plotting works perfectly. And interestingly, when I go to the suggestions, the suggested time series charts are correctly rendered…
Also when I remove the relative time + time shift setting it’s being rendered like intended.
- The graph should also be plotted in the panel, not only in the suggestions
Influx Query:
import "math" w = 15m historical = from(bucket: "evcc") |> range(start: 2026-01-05T11:09:04.791Z, stop: 2026-01-06T23:09:04.791Z) |> filter(fn: (r) => r._measurement == "tariffGrid") |> filter(fn: (r) => r._field == "value") |> filter(fn: (r) => r._time < now()) |> aggregateWindow(every: w, fn: last, createEmpty: false, timeSrc: "_start") |> map(fn: (r) => ({ _time: r._time, _value: int(v: math.round(x: float(v: r._value) * 100.0)), _field: "value", _measurement: "grid_price_ct" })) forecast = from(bucket: "MQTT") |> range(start: 2026-01-05T11:09:04.791Z, stop: 2026-01-06T23:09:04.791Z) |> filter(fn: (r) => r._measurement == "evcc_grid_forecast") |> filter(fn: (r) => r._field == "value") |> filter(fn: (r) => r._time >= now()) |> aggregateWindow(every: w, fn: last, createEmpty: false, timeSrc: "_start") |> map(fn: (r) => ({ _time: r._time, _value: int(v: math.round(x: float(v: r._value) * 100.0)), _field: "value", _measurement: "grid_price_ct" })) union(tables: [historical, forecast]) |> sort(columns: ["_time"]) -
Panel JSON
{ "id": 102, "type": "timeseries", "title": "New panel", "gridPos": { "x": 0, "y": 0, "h": 8, "w": 12 }, "fieldConfig": { "defaults": { "custom": { "drawStyle": "line", "lineInterpolation": "linear", "barAlignment": 0, "barWidthFactor": 0.6, "lineWidth": 2, "fillOpacity": 25, "gradientMode": "hue", "spanNulls": false, "insertNulls": false, "showPoints": "always", "showValues": false, "pointSize": 5, "stacking": { "mode": "none", "group": "A" }, "axisPlacement": "auto", "axisLabel": "", "axisColorMode": "text", "axisBorderShow": false, "scaleDistribution": { "type": "linear" }, "axisCenteredZero": false, "hideFrom": { "tooltip": false, "viz": false, "legend": false }, "thresholdsStyle": { "mode": "off" }, "lineStyle": { "fill": "solid" }, "axisSoftMin": 16, "axisSoftMax": 50 }, "color": { "mode": "fixed" }, "mappings": [], "thresholds": { "mode": "absolute", "steps": [ { "value": null, "color": "green" }, { "value": 80, "color": "red" } ] }, "unit": "ct", "fieldMinMax": false, "decimals": 1 }, "overrides": [ { "matcher": { "id": "byName", "options": "value" }, "properties": [ { "id": "thresholds", "value": { "mode": "absolute", "steps": [ { "color": "purple", "value": null }, { "value": 20, "color": "green" }, { "value": 30, "color": "#EAB839" }, { "color": "red", "value": 40 } ] } }, { "id": "color", "value": { "mode": "thresholds" } } ] }, { "matcher": { "id": "byName", "options": "Time" }, "properties": [] } ] }, "transparent": true, "pluginVersion": "12.3.1", "targets": [ { "datasource": { "type": "influxdb", "uid": "ef1j88sgykg00c" }, "refId": "A", "query": "import \"math\"\n\nw = 15m\n\nhistorical =\n from(bucket: \"evcc\")\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\n |> filter(fn: (r) => r._measurement == \"tariffGrid\")\n |> filter(fn: (r) => r._field == \"value\")\n |> filter(fn: (r) => r._time < now())\n |> aggregateWindow(every: w, fn: last, createEmpty: false, timeSrc: \"_start\")\n |> map(fn: (r) => ({\n _time: r._time,\n _value: int(v: math.round(x: float(v: r._value) * 100.0)),\n _field: \"value\",\n _measurement: \"grid_price_ct\"\n }))\n\nforecast =\n from(bucket: \"MQTT\")\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\n |> filter(fn: (r) => r._measurement == \"evcc_grid_forecast\")\n |> filter(fn: (r) => r._field == \"value\")\n |> filter(fn: (r) => r._time >= now())\n |> aggregateWindow(every: w, fn: last, createEmpty: false, timeSrc: \"_start\")\n |> map(fn: (r) => ({\n _time: r._time,\n _value: int(v: math.round(x: float(v: r._value) * 100.0)),\n _field: \"value\",\n _measurement: \"grid_price_ct\"\n }))\n\nunion(tables: [historical, forecast])\n |> sort(columns: [\"_time\"])" } ], "datasource": { "uid": "ef1j88sgykg00c", "type": "influxdb" }, "interval": "15m", "options": { "tooltip": { "mode": "single", "sort": "none", "hideZeros": false }, "legend": { "showLegend": false, "displayMode": "hidden", "placement": "right", "calcs": [] } }, "timeFrom": "+36h", "timeShift": "12h", "hideTimeOverride": false }
- no errors showing up
thanks a lot in advance! ![]()
