Table-panel search via <CTRL>+F
in earlier versions of Grafana (< 7.4) the complete contents inside a table-panel were searchable via the key combination +F. In newer versions only the visible area of the table-panel is searchable using +F.
In newer versions of Grafana the filter function in the table-panel was extended. Filtering data does not help very much, because the search is limited to columns. Our users like the CTRG+F very much.
Is there a possible solution to search the complete table?
