Dear grafana community,
is there any workaround to modify the table row height?
I used sanitize html option until Grafana 7 to dispay images in a table with specific height. Thus, the row was automatically widened in height. Now, I use table-old panel but want to change to the new table plugin. Displaying image without html works with “Cell display mode”, but the row hight can not be set anymore without html. This results in too small images.
Since the content should be both, text and image, dynamic image panel is no solution. The workaround could also include CSS or JS modifications.
table-old (image through html code with sanitize)
table (image through URL and cell display mode)
Thank you very much
@moderators please move the post to Table topic, I did not have enough permissions to post it there.
