Can anyone please help with below query. Details are as below.
V9.2.3 -
I am trying to adjust the image size in table panel’s cell however looks like HTML tags are not working with table panel anymore with latest version. -
I have provided a image source tag as column value e.g.
- What happened?
however it does show up an image. This is because the html doesn’t work in table panel in the new versions anymore - What did you expect to happen?
Image should be displayed in the cell and further I can add tags to adjust the size of the image per requirement - Can you copy/paste the configuration(s) that you are having problems with?
table panel column value “< img src =”/public/img/image.png" />" - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
It doesn’t display the image. However ij i just give the column value as public/img/image.png instead of tag the image displays however with this option I will not be able to modify the image - Did you follow any online instructions? If so, what is the URL?
Yes I tried to use old table panel. It shows installed in plugins however it does not show up under visualisation. Am I missing anything here?
Thanks for your help!
