Grafana v10.4.7
I am trying to display a field in a table panel which has multiple spaces between words.
I am using a table panel
What happened?
When my data has multiple spaces between words, e.g.
My Name
, only one space is being displayed. -
There should be some way to display the spaces as non-breaking spaces.
I have tried to use a MySQL replace query like:
SELECT REPLACE(column, ’ ', ’ ')
but it is displaying as ’ ’ on the panel.
Please help.
Thanks!
