Hello, i’m using grafana with (mssql data source), and i’m wondering if it’s possible to add a collumn on a table then fill it with links to other websites
2019-08-20T22:00:00Z
Yes, add a column style and check the render value as link
hi torkel
Sorry i’m not able to do it, how can i add a collumn from grafana or should i create the collumn from sql ?then i’m not sure how to do to fill the collumns with the url
thanks
