Dear there, I got a problem with table panel , data can not sorted by number. It is sorted by the first number when I click on the header. grafana v8.5.6
Thank for your service. Good luck.
It’s ok now. I use “transform” — “Convert field type” ,Convert field type to “Numeric”。
