Hi, we are using the table panel to display prometheus alerts like
| alertname | severity | additionalinfo |
| alert1 | critical | something |
| alert2 | info | something |
| alert3 | warning | something |
9.2.2 -
Sort the table by severity NOT alphabetically but in order “critical”, “warning”, “info” -
Transformation sort is sorting alphabetically/numerically by a column.
I was looking for a transformation to map a string to a numeric value like
“critical=>1, warning=>2, info=3” , to then sort by the new colum, however I didn’t find that in Grafana. -
What happened?
I run out of ideas what I could try
Sorting by the real level of severity.
Thanks in advance
