I’m having some trouble sorting a column of data in a table panel. As you can see in the data inspector, it is not sorting correctly (both ascending and descending). It is not in any order without any sorting applied either. The behaviour is the same in the table itself too.
The JSON panel data seems to show the data is in the form of numbers rather than strings.
Any thoughts would be much appreciated. I am relatively new to Grafana - and working on databases generated by someone else - so I could be making a simple mistake.
Thanks ![]()
