Hello!
It happens quite often Stat panel shows state ON, but lower graph show OFF. Actual state is ON.
Is there any solution to put in order those two indicators to show same state?
Thank You!
Hello!
Thank You!
Any chance you can post data in table format?
Good point. I have found out an error. Data format was string instead of float or any other numeric format. I couldn’t imagine Grafana can interpret string as - almost correct - numeric result.
