Version 10.1.0 under a RASPI with Debian/Bullseye -
Get a correct calculation
What happened?
I have a Dashboard with a Statpanel, where the calculations are wrong.
When i switch to the table-view there is one entry with a value of 1.85. This is shown in the graph. Calculation is zero. -
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors
