Grafana v11.2.0-74290 (8988e04044) Cloud -
Make displayed percentage within Stat visualization show correct values. -
Using Infiniti plugin, a basic dashboard, Stat visualization, Show Percentage Change toggle -
What happened?
All percentages shown are 100x their actual value.
Example: Old value = 9, New value = 5.
Verified the JSON “diffperc” below shows correct value. But panel shows -4,440%"state": { "calcs": { "sum": 14, "max": 9, "min": 5, "logmin": 5, "mean": 7, "last": 5, "first": 9, "lastNotNull": 5, "firstNotNull": 9, "count": 2, "nonNullCount": 2, "allIsNull": false, "allIsZero": false, "range": 4, "diff": -4, "delta": 5, "step": -4, **"diffperc": -44.44444444444444,** "previousDeltaUp": false
Any assistance would be greatly appreciated! Thanks!
