v7.0.3 -
calculating a percentage from 2 subqueries, where output is (A-B)/A, where A and B are the results of 2 subqueries -
in query -
What happened?
i get the expected result when i am in the “edit panel” and sometimes when i switch back to dashboard. but after a moment, the value changes to something completely different and incorrect. -
to have the correct value shown in the dashboard. -
where do i find this? -
no
What datasource are you querying? Can you share some screenshots of your data and the issue? Are you using transformations to achieve your goal?
